Home > Maintenance & Modifications > Maintenance of drive flanges
Greadh
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Seen a few people struggling to remove drive flanges off the end of the half shaft and ended up cutting them off. There always seems to be comments stating it's due to lack of maintenance........ But what maintenance can be done? Remove flanges every now and again, copper grease the splines, new gasket and refit? That's about all I can actually think of in regarded to maintenance of them.
Post #771027 1st May 2019 10:16am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Yep, that's about it. Keep them greased and it also slows down the wear on the splines Thumbs Up
Post #771033 1st May 2019 10:44am
lohr500
I think that's the long and short of it.
Worth getting a correct sized tap though to clean out the threads as the bolts are held in place with threadlock and are prone to shearing on reassembly if the bolt and hole threads aren't cleaned. Either buy new pre-coated threadlock bolts, or use some threadlock from a tube, or use spring washers.
The old Series vehicles used spring washers and in all the years I ran them, I never had a drive flange bolt work loose.
When I first checked my rears (only 15,000 miles/ 2 1/2 years old) I was shocked how much red dust there was in the rear plastic end covers and the fact that there appeared to be zero lubrication.
I used multipurpose grease though, not copperslip. Not sure which grease is best for the job, but anything has got to be better than nothing.
At the time, there was still plenty of life left in the drive flanges so I didn't replace the ends or the shafts. I think I caught them early enough.
I used to pull the caps off at service time and pack fresh grease into the splines.
A couple of years later, before I sold mine, for peace of mind and to try and reduce the amount of drivetrain slop, I was going to replace the rear halfshafts with the one piece design and use socket cap screws/split washers in place of the bolts/threadlock. But never got round to doing it.
Post #771034 1st May 2019 10:49am
Greadh
thanks for confirming, now you mention it grease is probably better than copper slip (unless anyone can correct me). doing breakpads soon so will 'maintain' the flanges at the same time:-)
Post #771036 1st May 2019 11:11am
From an engineering standpoint this isn't very good practice, since a tap will almost certainly end up over-sizing the thread. You are better off using a thread chaser.
If you don't have such a thing a substitute can easily be made by running a thin cutting disk up the length of an M10 bolt. When chasing the threads, make sure that you stop frequently to clear the dislodged gunge from the hole.
Personally I never use any form of thread lock on these bolts, since in my view it is wholly unnecessary and only leads to problems.
Post #771048 1st May 2019 1:47pm
Greadh
thanks for the suggestions, I will do just that.
Post #771054 1st May 2019 2:46pm
Mo Murphy
I too have never felt the need to use thread locker on drive flange bolts nor had them come loose, I just make sure the threads are clean and torque them up to 65NM. Bolts loosening are often the result of over tightening and stretched bolts.
If the vehicle is new to you then consider using new bolts on the drive flanges and start with a known clean sheet.
50 Shades of Pennine Grey
Post #771058 1st May 2019 3:40pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I used motorcycle aerosol chain lube on my drive flanges. It goes in very easily and once the solvent evaporates, you're left with a decent coating on the splines.
However I've now changed the rears for the early Discovery one piece ones which is a doddle to do and gets rid of half the potential priblems.
Post #771065 1st May 2019 4:50pm
