![]() | Home > In Car Electronics > Running Voltage |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917
Hi, I can't help on the specific question of the voltage as I've never had a voltmeter fitted, and my car is an old 300Tdi anyway.
But I was struck by your comments about the car feeling 'lighter' and 'heavier'. I think there's a risk that, when we think something's wrong that we imagine or attribute noises or 'symptoms' to our perceived fault. Assuming you car is a diesel, then as far as I'm aware, the battery gets it started, and the current keeps the fuel solenoid open, but the engine is essentially running independently of the battery. Charging it if needed, but not putting any material draw or load on it? I guess the other issue, with more modern vehicles, is if the dunking has affected the ECU. I presume you've had that looked at somehow? My apologies if this is completely obvious to you - not tyring to teach anyone the basics! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 824
Hi Donald,
Thanks for the input, with regards to the items you pointed out, ECU is also new, so is the alternator. |
