Home > Puma (Tdci) > Rear door lock barrel
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
How do you remove the lock barrel from the latch??
There is not a small hole with a pin??
Advice appreciated
Thanks
Post #768343 12th Apr 2019 9:37pm
mk1collector
Drill a hole in the correct place so you can put a pin in. Ray
My build thread
Post #768380 13th Apr 2019 9:25am
dorsetsmith
Second row door lock barrel or rear door Question
Post #768385 13th Apr 2019 9:49am
boxoftricks
Rear door.
Post #768411 13th Apr 2019 1:30pm
dorsetsmith
That depends on the age of the door/lock.
Earlier versions have a short barrel and there is a hole in the outer tube that houses the barrel. You poke something into the hole and depress the plunger allowing the barrel to slide out.
Later locks use a longer barrel and, as a result, the plunger is much further into the tube. This means that the hole is actually inside the lock mechanism and you have to access it through the slot in the top of the mechanism where the central locking lever would/does come through. On this type you can remove the barrel without removing the lock mechanism although you still need to remove the door card.
Post #768415 13th Apr 2019 2:24pm
boxoftricks
Great thanks I’ve spotted the pin through the top
Post #768417 13th Apr 2019 2:49pm
