![]() | Home > Maintenance & Modifications > replacing brake calipers |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I just opted for a set of stainless pistons and new genuine seals. Nothing wrong with the actual Calipers on mine though. Just a couple sticky pistons.
![]() Instagram - @r22oyp Roy |
From what I was led to believe (by my local parts shop) the majority of "new" brake callipers for Defenders and pre-Disco 3 are in fact reconditioned items so I expect you will be just fine with Britpart callipers. Take the above as you like, but I have had Britpart callipers on Miffy for four years now and they are still A-OK. Had Britpart drilled and grooved discs on for a good three years as well. All good and Miffy is a heavy beast with her cage on so they get a good workout. Never had a problem with any Britpart item. Now Bearmach on the other hand, eeeshk does the TD5 in tank pump make a lot of noise... Straight out of the box too... Should have gone with a VDO item... ![]() |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
I also did that, was amazed how easy it was and still going strong 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1658 ![]() ![]() |
come on why would you.......
ill send you some bearmach ones 3yr warranty. fitted plenty and only had 1 faulty set(seals leaked from 1st fit) they just replaced them. oe ones i think have a better / firmer pedal feel sometimes |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8381 ![]() ![]() ![]() |
Food for thought, Thank you all. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17918 ![]() ![]() ![]() |
I really cannot think of any circumstances under which I would consider fitting Britpart calipers to any vehicle of mine.
I accept that many people have good experiences with the brand, I have not, and I do not recall ever having bought a Britpart component which was wholly satisfactory, and some components have been entirely useless (for example hub nut which don't fit the stub axle). I have had unsatisfactory parts from other suppliers, but no other source has managed to supply such a high proportion of duds. As for a safety-critical part, or a part critical to the reliability of the vehicle, I think Hell would freeze over before I went down the Britpart route. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Delphi just fitted to mine.
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
My father had a saying, "You only get what you pay for, if you buy cheap then that's what you get".
You have to remember you rely upon them to stop your vehicle every time you drive it. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
clearly if you live at the bottom of a very steep hill its not a problem as gravity will stop you on the way up
^^^But what's going to stop you when you return to your house?
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Specified Zeus to be fitted on mine, together with genuine seals. Zeus are in Dunkeswell so quite convenient for you I would think?
oh yes that could be awkward ![]() ![]() I'd go for the stainless pistons. being thinking about doing it for ages myself...... |
