Home > Maintenance & Modifications > Shocks and springs D90 TD5
Djcla
Hey all what's the recommendation on replacement shocks and springs Standard height? Was looking on ECP at Sachs but no idea really, so any recommendations?.
Post #766241 31st Mar 2019 2:23pm
Why are you replacing what you already have and what do you use the vehicle for? Darren
Post #766259 31st Mar 2019 4:58pm
Djcla
Replacing because I fear it's on the same set for a long time and the right isn't great especially in the back.
Mix of on and off road so really looking to improve the ride.
Post #766280 31st Mar 2019 8:02pm
If you're looking to replace worn out originals, then you won't go far wrong by replacing them with new versions of the same (Armstrong shocks, not Britpart). If you run near to empty and find the back a bit harsh then something like the comfort springs from Alive may fit the bill, albeit at the sacrifice of some load carrying ability.
Alternatively, a combination of standard springs and Bilstein B6 dampers have a good reputation. Darren
Post #766292 31st Mar 2019 8:50pm
Djcla
Was just looking into the Bilstein B6 dampers and standard springs combo actually, looks good.
Post #766294 31st Mar 2019 8:53pm
