Home > Maintenance & Modifications > Been laid up - should I service?
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
I’ve been pretty busy over the last few years moving between 3 countries etc etc - hence the Defender has done about 2000 miles in the last 2 years (1000 of that was driving to Germany and back).
It has its final service from a main dealer in 2017 - the service light has just come on and it’s booked into a local independent that I trust. 4th service so should be a big one.
My issue though.... it’s going to be laid up again Shocked probably for the next 2 years. Should I bother getting it done! Or just do the engine oil and leave the rest?
Advice welcome - If I ignore it, what are the risks?
Thanks
Ian
Post #765593 27th Mar 2019 7:28am
ericvv
I would do engine oil and filter, a good greasing job of the props, and don’t forget to replace the brake fluid too. Fresh oil and grease are a good thing, while brake fluid is hygroscopic and attracts moisture irrespective of mileage done. That’s why it needs to be replaced every two years.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #765602 27th Mar 2019 8:39am
AJC
I honestly wouldn't waste your money.
If it's literally not moving for 2 years potentially, I'd jack it up and leave it on axle stands and not touch it.
when it does come to fire it up, I'd let it turn over for a while first and then let it fire up,
only thing I'd consider in this time is the cambelt detoritating
Post #765603 27th Mar 2019 8:44am
lohr500
Cambelt? I'm guessing it's a Puma if it had it's final service in 2017. So it should have a chain shouldn't it?
Post #765617 27th Mar 2019 11:06am
AJC
ignore my cambelt comment!
Post #765619 27th Mar 2019 11:15am
Caterham
I'd just do the engine oil and filter.
Thumbs Up
Post #765625 27th Mar 2019 11:46am
Higgers
Thanks all 👍
Post #765739 27th Mar 2019 11:33pm
leeds
Battery on a trickle charger?
Brendan
Post #765743 28th Mar 2019 12:50am
LR90XS2011
Id do everything Eric suggests, water is you enemy replace any fluids or greases that could contain water. Remembering that even the engine gets condensation forming in it. It is is mistake to change the oil post storage it should be done pre storage. DEFENDER 90 TDCI XS,
Post #765745 28th Mar 2019 6:44am
Procta
you could give it the big one, but again with the mileage its done, are they going to do the service. They maybe taking your money and stamping the book and that's it. I have been told a few stories of places doing that sort of thing, due to the motor not doing the mileage.
I would check it over myself and then put the motor on axle stands, remove anything that will cause dampness and remove the radio if possible and remove the steering wheel.
If possible i would even start her every so often. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #765746 28th Mar 2019 7:07am
jst
Park it up, over inflate tyres, put on a trickle charge.
When you get back, put 100miles on her and change the oils. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #765752 28th Mar 2019 8:38am
dorsetsmith
^ you starting point and good viall inspection too
Post #765758 28th Mar 2019 9:37am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Change engine oil and filter, Acids in the oil can attack components in the engine.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #765781 28th Mar 2019 1:34pm
^^ this plus check engine/gearbox/xfr box seals, CVs and lube the central locking solenoids
Post #765796 28th Mar 2019 2:51pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
What ever you do something will be broken when you come to use it
Post #765860 28th Mar 2019 10:22pm
