![]() | Home > Maintenance & Modifications > Victron 230 amp split charge question. |
jocklandjohn Member Since: 16 Sep 2016 Location: Highlands Posts: 62 ![]() ![]() ![]() |
I've got an IBS 'intelligent' split charge system. If the starter battery does get flat (which the IBS should prevent in the first place) you simply press a button, both batteries are temporarily linked and you simply hit the starter. Once the engine fires and the alternator is feeding back into the system the link function drops out. Works fine and I've had to use it a few times - and its quick and simple. Not sure about the Victron unit though.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
Thanks. Can you tell me what fuses you have between the two batteries? 2007 110 TDCi Station Wagon XS
Never paid much attnetion to be honest - so just popped the holder just now and they're 40A with a 100A relay.
Just checked the link function - its on a timer (rather than charge-controlled), and one press on the link button gives a 30 minute connection, which can be repeated. This is an old unit (over 20 years now) and the newer ones have far more functionality/connectivity.
