Home > Maintenance & Modifications > window block bolt removal - any suggestions?
donmacn
Hi,
As usual, tried a wee search, and nothing came up in the first couple of pages.
I tried removing my window blocks today, to fit new ones bought from Huttopia here. On the first one (ns) the two lower bolts through the bulkead came off fine; the top one, through the aluminium window frame just sheared.
On the other side, I was expecting the worse, but they all came out OK.
So I'm left with one bolt that seems very solidly stuck into the windscreen frame. Good, old alu/steel corrosion again.
It won't budge with a punch and hammer. I gave it some hefty thumps, but any harder and i'm worried I'll do more damage. I don't think I can get any heat in there without melting other stuff.....
I've left it with some plusgas soaking in, but the only thing I can think to do is to drill it out; starting small, then progressively bigger drills.
Has anyone else tackled this (i assume so) and what other options might I have? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #764895 22nd Mar 2019 9:17pm
LR90XS2011
i think I would try what you suggest and drill it out bit by bit DEFENDER 90 TDCI XS,
Post #764936 23rd Mar 2019 8:51am
donmacn
Thanks,
It also occurred to me that this could be the moment to buy a 'proper' stud extractor set. I have some cheapies, but one of them broke - split into two - the first time I tried to use it. An Irwin set is about £30 and I'd always found excuses to get something else, but I might give that a go first. If it works, it'll be £30 very well spent. Donald
in the past..
Post #764941 23rd Mar 2019 10:07am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Not had much success with stud extractors with really stuck bolts. The original bolts are only threaded into the window blocks so should have tapped out. Probably best bet to drill and the heat generated might break the corrosion, or weaken the bolt sufficiently to tap out.
Be careful when the blocks are loose as the frame can move and then a nightmare to relocate the holes.
Post #764946 23rd Mar 2019 10:41am
landy andy
Drill it out would be my choice. You’ve just got to start very small, and get the first hole spot on central and accurate then the rest is easy.
Post #764955 23rd Mar 2019 11:13am
donmacn
Well, I did get a better set of bolt/stud extractors, but there just wasn't enough of it left to get a grip on, so drilling it out was the only option. 3mm > 4mm > 6mm.
I obviously didn't get it completely centered, but not too bad.
Even at this stage I needed to use a long thin punch to drive it out.
Aaand, it's not a pretty sight underneath.
I'll tidy it up, and see if I can get a reasonably level surface for painting/sealing. I might also see if I can pick up a spare for future use in needed. At least a windscreen frame is easier to replace than a bulkhead.
Thanks again for the advice. Donald
in the past..
Post #765054 23rd Mar 2019 8:49pm
LR90XS2011
well done mate, lots of Wax when you reassemble DEFENDER 90 TDCI XS,
Post #765056 23rd Mar 2019 8:53pm
donmacn
Thanks!
I know I'll need to do something to keep the metals apart on re-assembly. I was thinking duralac - which I use quite regularly - or maybe even wrapping the bolts in plumbers PTFE tape. Donald
in the past..
Post #765059 23rd Mar 2019 9:05pm
PCM
You can add a gasket as shown bu Powerful as an extra barrier.
Post #765064 23rd Mar 2019 9:22pm
donmacn
Thanks. Yeah, I bought the window blocks from Huttopia on here. He supplied a good gasket set.
But actually I think there are two problems. The first is the thread in the block itself, where a steel bolt is threaded into an aluminium thread; second is the hole in the window frame that the bolt passes through.
In the one above, I think the corrosion had happened in both of these places.
I'm sure that keeping the water out in the first place will reduce the amount of bi-metal corrosion, but it probably needs a little more than that in the long run? Donald
in the past..
Post #765067 23rd Mar 2019 9:29pm
Balvaig
Glad you managed to get it out in the end.
You should be able to rub down the corrosion and get a decent finish.
When I replaced my widow blocks I used clear Dinitrol wax as a sealant/ protectant both on the gaskets, in the back of the window blocks and in the hole in the frame. Only time will tell if this is sucessful but it has to be better than the original LR solution.
Stephen
Post #765082 23rd Mar 2019 10:26pm
jst
Left hand drill bits work well for drilling out stuck studs. Start small normal drill bit, then get a large oversized lh drill bit to bite into the end. The heat from the initial small bit helps heat the bolt and often the large lh bit will bite and then unscrew the bolt.
How ever in the case shown I don't think that bolt was ever likely to come out. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #765088 23rd Mar 2019 11:08pm
ericvv
donmacn wrote:
Thanks!
Duralac hardens quickly. This here is much better. Learned this from a German Defender wizzard, I use it for years now on standard mild steel door bolts, and it never hardens and zero rust. Also use it to lubricate other things like for instance the bonnet catch mechanism, just works perfectly and doesn’t harden. Apply liberally.
Eric
If you don’t find the above which is a more recent formula, the version below which is the actual one on my door bolts is equally good.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #765097 24th Mar 2019 6:02am
Another vote for Weicon paste, excellent stuff albeit pricey (also messy). Available via Amazon.
Post #765113 24th Mar 2019 9:55am
Fat Cog
Before you refit them smear ACF50 corrosion block grease on the gaskets, in the holes etc...great stuff.
http://www.acf-50.co.uk/corrosion_block.htm
And Huttopias blocks are top notch... Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #765114 24th Mar 2019 9:59am
