Home > Puma (Tdci) > ANTISTALL FEATURE
Page 2 of 2 <12
chalky
I guess the Experience centres would be the place to glean this information from !
they should have the difinative. DEFENDER XS CSW 08 TONGA GREEN
Post #5065 27th Nov 2008 9:32am
AndrewS
I doubt that. I raised these questions at LRE in Solihull and the answer was Shocked er don't know.
Red Defender
Anti stall and idle ramp are seperate issues. Anti stall does as it says, and work in high and low box. Idle ramp only works in low 1st and reverse and increases tick over. The numbers given are from LR and are used by all the LRE centres.
Yes they are separate features. Thumbs Up
The idle ramp or jack is there to reduce the engine breaking. When the very 'torquey' Puma engine (long stroke) is shut off there is so much engine breaking it actually locks up the wheels thereby inducing a slide. The easy fix is to lift the idle on low 1st to reduce the engine braking.
http://www.defender2.net/forum/topic423.html?highlight=
Post #5073 27th Nov 2008 8:26pm
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
After a similar discusion on another forum I tested the downhill descent capabillities on my Puma by comparng it to a friends Td5. The Puma is better and more controlled on very steep slippery descents, not nesecarily slower though, the problem is that if you want to go slower than what the Puma wants you too it is going to slide anyway = less control.
The Td5 can descent slower with some driver intervention, the Puma should be left to control the descent.
If you stop above the slope a short disance away from it as opposed to right against it the idle ramp is not an issue because the revs drop before you get to the slope, or don't stop at all (this pplies to rock crawling too), make sure you're in 1st low and leave all the pedals, the vehicle descends better than a Td5, it feels a little strange because you want to feather the brake (we want to be in control), this causes the revs to lift again though and you go rushing down the slope.
On a Td5 it feels like you are more in control because you can actually do something to try and slow your descent, but it is not neseceraly the case though.
Post #5422 11th Dec 2008 7:16am
Laurie
The TD5 Handbook doesn't even mention the existance of an anti-stall facility!
Post #5434 11th Dec 2008 2:23pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
There is no anti stall on a TD5 Thumbs Up
Post #5436 11th Dec 2008 5:48pm
mse
Errmm When playing on a carity event at Gaydon the LRE guys said the td5 we were in had anti-stall (55 plate or 06) Mike
Post #5438 11th Dec 2008 7:45pm
Laurie
That's what they told me.
Post #5439 11th Dec 2008 7:50pm
rustandoil2
TD5 antistall in action Here
and Here
Post #5460 13th Dec 2008 1:26pm
Tatt
South Africa 2002 Defender 110 Td5 HT Belize Green
Yup, my 2002 110 TD5 Van has anti-stall. Great for when you stuck in traffic jams!!
Tom
Post #5488 14th Dec 2008 7:46pm
alantd
Tom
Second that
Post #5542 15th Dec 2008 11:24pm
Bosun
Yep, Ronnie Dale at the LRE Coniston Hall told us about anti-stall on the TD5 some time ago, although I'm not sure it was that good.
Bosun.
Post #5546 16th Dec 2008 8:15am
mse
Bosun.
no i stalled it when manovering Whistle Mike
Post #5564 16th Dec 2008 5:37pm
Laurie
Mine has a habit of occasionally turning off for a few minutes - Usually at the most inopportune moments Sad
Post #5574 16th Dec 2008 8:46pm
jst
td5 does have antistall but it turns off as soon as you touch the accelerator.
the idea of Idle Jack was to increase to 1100rpm in 1st and rev low box only as already mentioned. if it doesnt go to 1100rpm then something is not as it was designed.
the reason for this is due to the lower (33%) gearing in 1st gear when compared to a td5 defender to try and give the same descent speeds (not sure what the Rev ratio difference is if any?)
the problem as rightly pointed out occurs when trying to cadence brake on a descent to slow the speed further then anti stall comes in and works with idle jack to maintain the 1100rpm, you pushing the foot brake to slow it is the same in essence as the vehicle coming to a hill and meeting resistance so it puts in more fuel.
it takes a while to get used to.
Shame LRE solihull couldn't answer the question. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5579 16th Dec 2008 10:34pm
jst
forgot to add that don't forget the vehicles are designed for the average user, the average off road driver will hopefully have some basic trg which is dont touch the pedals on a descent - therefore the system works, its when you start to look at advanced driving techniques the problem manifest and this can be got around safely, and if your trying that then you may be (or think you are) beyond the basic level. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #5580 16th Dec 2008 10:38pm
Page 2 of 2 <12
