Home > Technical > Oily residue in clean side of air filter. Normal?
Co1
I have some sort of oily residue on what should be the clean side of the filter in the duct that takes the air toward the engine. It seems to start where the smaller bore hose joins this duct, but I never checked where that one comes from, I assume it’s some sort of breather or recirc. It’s a 2013 Puma. The pic isn’t great, but should give you an idea.
Is it anything to worry about or perfectly normal, or both in true Landy fashion!
Post #764347 19th Mar 2019 7:13pm
LR90XS2011
perfectly normal, if you search "provent" you will find a thread on here all about it DEFENDER 90 TDCI XS,
Post #764350 19th Mar 2019 7:30pm
Co1
Cheers. Is a catch can the solution, or not necessary?
Post #764351 19th Mar 2019 7:34pm
