![]() | Home > Maintenance & Modifications > Mantec Wheel Carrier woes. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4319 ![]() ![]() ![]() |
The original rubber washer is not 15mm thick from memory, but they do fall apart so maybe yours has been replaced before. I am about to replace mine, going to try To adapt a lower rear shock bush. 2007 110 TDCi Station Wagon XS
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
I fitted mine last week. I tightened up the nuts you refer to in part two just enough so the carrier does not rattle or move when you give it a good shake.
I also Cooper greased the hinge bolts that are not done up that tight so it’s light and easy to swing the wheel away. I think I need to realign mine slightly to take weight off the door more. |
I must have had a lot of spare time on my hands when I fitted my Mantec. I cross drilled the two hinge bolts about halfway down the thread and then drilled down the centre line of the bolts from the head end until it met the cross drilled hole. Screwed a grease nipple in the head. I can now easily grease the hinges. 2007 110 TDCi Station Wagon XS
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
I found that i needed to tighten the hinge bolts up so as the arm doesn't bounce , tight then backed off half a turn. Conflicting advice I know ![]() |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
I had a similar problem, could be your issue.
https://www.defender2.net/forum/topic20067.html |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
I replaced those 2 bolts with nyloc bolts and cranked them down either side of that bracket, I also greased the hell out of that piston... that stopped it rattling.
petestaunch Member Since: 19 Nov 2016 Location: Wales Posts: 65 ![]() ![]() ![]() |
Thank you all very much. Really appreciate it. It seems I have the order of fastenings incorrect at the very least.
Pete |
