Home > Technical > Suspension bushes
Grenadier
Suspension bushes
Hello all,
Can anyone clarify what/how many bushes I need to order for a complete suspension change?
I'm looking at buying OEM, but none of the reputable on-line suppliers does a complete kit like Polybush etc. I'm happy to buy extra bushes for panrods, trailing arms, radius arms, ARB etc, but at the very least I want to understand what I need for front and rear suspension.
I am looking at Famous Four's website, and think I need three bushes (two bottom, one top) for the rear suspension, but for the life of me I cannot work out what is needed on the front. Any help would be gratefully received Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #762873 11th Mar 2019 11:08am
excossack
Rear Axle
Trailing arm
2 each side at the chassis end - 30mm I think for the nut
2 for the Trailing arms (1 each axle end) - 24mm I think for the nut
If doing A frame bushes, the ball joint and then one for each end of the A frame to chassis mount
Front axle
2 each side for the radius arm at the chassis end- 30mm I think for the nut
2 each for axle end of the radius arm - 24mm I think for the nut
2 for panhard rod
plus any nuts and bolts required. Not sure on bushes required for shock absorbers. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #762886 11th Mar 2019 1:14pm
