Home > Td5 > Belt Catastrophe - Steering pump? |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
Hi Folks!
I had been hearing some humming sounds when the car is in gear. Kind of like a whining humming noise. I've also been noticing prior to this that there has been some fluids dripping from somewhere above the steering damper. This is a LHD 110. 1999 TD5. I thought this might have been from loss of power steering fluid. So i went to buy some ATF (which might have been a mistake). Two days later, I'm driving and the noise isnt getting much better only when in gear! AND THEN! Smoke comes out of the hood, the steering is super stiff and brakes are extremely hard to push down. I open up the hood and this is what it looks like. One of the pulleys the bearings are shot. What could have caused this? Would it be a steering pump failure or????? |
11th Mar 2019 5:27am |
kevinp Member Since: 30 Dec 2015 Location: west sussex Posts: 5 |
old age bearings dont last forever unless you are very lucky
11th Mar 2019 7:16am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Clearly something has seized up in there and shredded the belt, easy enough to check though, just remove the remains of the belt and spin the relevant pulleys by hand.
11th Mar 2019 10:40am |
UGGHHHHH!!!!!
11th Mar 2019 6:54pm |
First change the bearings or the whole pully's. If you can spin the pump by hand I would try that first. Roel
11th Mar 2019 8:55pm |
Click image to enlarge Click image to enlarge |
11th Mar 2019 11:54pm |
