![]() | Home > Technical > Front swivel housings - interchangeable? |
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
....so many questions, so little time..!
Are front swivel housings interchangeable? Not the swivel balls, but the housings. I have the later ones without the drain plug. Can I use the older ones with filling and drain plugs? Or would I need to change a whole lot of other bits? Ta Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
I would have said they're interchangeable
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
All none ABS
Click image to enlarge raiko bush top pin on the left on the right post 1998 on words Click image to enlarge Click image to enlarge |
| All times are GMT |
