![]() | Home > Puma (Tdci) > Suspension - A softer ride required |
I have iron man "B" springs and OME shocks on my 90. The ride is superb and it handles fairly heavy loads equally well without being too stiff when unladen.
Springs from west coast 4x4 and shocks from gwyn lewis. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i use standard road springs, replaced the HDs on the back and Koni Heavy Tracks all round
it has truly transformed the ride and comfort. BM52 |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Shocks will make the biggest difference to the ride, followed by springs (particularly rear).
Then if you're feeling really flush, beefed up anti-roll bars. Fitted Bilsteins on my 110 and the ride is transformed - Much more supple. The fact that the OEM LAnd Rover shocks are £30-ish each RETAIL, gives you an idea of how much they cost to make! They're truly shi*e! ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Bilsteins
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
koni heavy trakcs
Actually on a landrover its springs that make the biggest difference rather than shocks. |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Since taking delivery of my brand new 110 XS a few weeks ago, I've had some lowered dual rate springs made, paired with standard spec Bilstein dampers all round. I also have a few options of rear anti-roll bar to test, to get the balance just right. The ride is lovely compared to standard, and towing ability & load capacity is unaffected.
Our Td5 90 uses custom made lowered progressive rate springs, with shortened and re-valved Bilstein dampers. The springs give a beautiful smooth ride, but the dampers and roll bars fitted were deliberately agressive to give pin sharp handling. It doesn't have to be that way though, as having tested Defender suspension to the extreme, we can tailor a spring/damper/roll bar package that will transform the way a Defender drives. One thing that is more difficult to change, is the bobbing that comes from the short wheel base of the 90. This is why a 110 gives a much nicer ride, and 130's even more so. Best Regards, Gary. |
Hi, anorak question ![]() ARB - i'm interested in a possible upgrade. Mine feels like it needs the rear more than the front......but i am no expert! Can you advise costs please. 90 vs 110 re ride. Yep, i see what you mean but i chose the 90 for overall convenience etc, just 2 of us in for 95%+ time. Cheers BM52 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2482 ![]() ![]() ![]() |
Gary are you aware of what kind of "valving" figures are std shoxs? thanks MK Puma 110" SW ............................................................. Earth first. Other planets later |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
As far as I know (I have a puma and some 300tdis, a 90, 2x110s and a 130) Land Rover Genuine shocks are actually quite good. Additionally it is easy to get and change the rubbers and washers when they wear out. On a set of OMEs I had I could not get new rubbers/washers.
Also the Puma 110 runs in gas shocks as standard and I have replaced these with the TD5/300tdi oil shocks and have improved my ride - made it softer and less skittish on rough roads. I still think the rear springs are too hard for my normal loading but have not got round to sorting it out. If you want to see the change in ride put a good load (300kgs) in the back of your car and go for a spin. If that gives you a good ride then you can decide what to do. I agree that aftermarket shocks (some times sold as OEM) from woodhead and armstrong are not so good. Shocks and springs work well if you match them to the weight you carry most of the time. On a normally loaded standard car going for anything with HD in the label will not give you a better ride. I run my 90 on 28 front and 30 rear using either 265/75/16s or 7.50/16s. |
I run 265's at 35 rear, 30 front. this is after a lot of experimentation with pressures.
if carrying heavy load I'll up the rear to 40 and the front to 32 |
Cowpat Member Since: 11 Apr 2011 Location: Stockbridge, Hampshire Posts: 12 ![]() ![]() |
Does anybody know what the JE Engineering kit is made up of? Apart from the shocks who do they use for their springs. The overall price fitted is massive! 1986 Defender 90 County V8
1997 Overfinch Defender 90 570HSI - Pass anything apart from a petrol pump! 2011 Defender 90 TDCI xs Best 4x4 by Far! |
Looking at the kit its geared towards sporty handling as opposed to offroad driving. the AR bars are enormous. I guess it depends on what you do with your vehicle, but I wouldn't have that kit, not suitable for me at a all.
BigMike,
Yeah, your right. I don't want the AR bars. I just wondered what the springs were. I'm taking your advice and checking out the OME Shocks. Cheers 1986 Defender 90 County V8 1997 Overfinch Defender 90 570HSI - Pass anything apart from a petrol pump! 2011 Defender 90 TDCI xs Best 4x4 by Far! |
