Home > Puma (Tdci) > Dim headlight drivers side only
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I have one headlight (driver's side) that's dimmer than the other.
I changed the bulbs and switched the headlights over & the driver's side headlamp is still dimmer.
I'm presuming I'm going to need to replace the cable and connector that side.
Anyone else had this issue?
- thanks
Post #760346 23rd Feb 2019 1:35pm
MK
I would check the ground and the connector plug itself. Puma 110" SW
Post #760352 23rd Feb 2019 2:01pm
leeds
A quick check with avoltmeter on both sides should be illuminating!
Does sound like voltage drop so check earths and connections. Next would be an upgraded wiring loom or approved LED headlights.
LED will normally work if the minimum voltage is applied typically around 9 volts.
Brendan
Post #760361 23rd Feb 2019 3:16pm
JPE
Thanks for the advice. Thumbs Up
I found I could pop open the connector and one of the connections had corroded and wasn't making a good connection.
That headlight is now a proper bright white, rather than orange, just waiting for it to get dark to try it out properly. Smile
Post #760371 23rd Feb 2019 5:07pm
Dinnu
Had this exact issue, on passenger side, and found bad connection on the H4 bulb connection.
What was strange is that with dim beam, the main beam indicator was illuminating dimly on the dash. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1031687 15th Apr 2024 7:06pm
