![]() | Home > Maintenance & Modifications > Stainless security bolts |
4x4 overlander sell the nakatanenga kit which is great and they are site sponsors too. Ray
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I have the Nakatanega vast kit on mine from 4x4OL. Excellent
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Well I do know that 4x4overlander sends rather a lot of the Nakatanenga stainless bolt kits down to a special address in Coventry.
![]() ![]() Now as for security stainless bolts, please remember most common ‘security’ bolts mean that the tools are also commonly available. Just have a look at the ‘security’ bits available in a lot of common tool kits. Now large companies can buy security bolts with ‘unique’ keys/tools that are not commonly available but they do buy in bulk. Now there are other alternatives such as knocking in 5 mm stainless ball bearings however they can be extremely awkward if you need to adjust doors etc. Other alternative is body filler which will take some time to dig out. Also remember mr angry grinder. Brendan |
Kilvo1 Member Since: 05 Feb 2019 Location: Berkshire Posts: 17 ![]() ![]() ![]() |
Thanks for the replies that is the exact kit I need
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
is it as straight forward as take one out put one in, or do you end up having to re hang and adjust etc
Pete |
One at a time and you won't loose alignment
Also use the paste supplied.
Brendan |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Does anyone have a list of the bolt sizes needed for the kit so I can order with unique security heads?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
... assuming that the doors are correctly aligned in the first place, which they probably aren't unless you've already re-hung them yourself! |
