Home > Td5 > Front axle breather
lightning
Front axle breather
How do l check if my front axle breather is blocked? Before l take the Defender in to get new oil seals l think it would be a good idea to see if the oil that’s started leaking from both swivels and the diff nose is due to a blocked breather.
Post #759498 18th Feb 2019 10:22pm
grafty99
Easiest way is to remove the diff filler plug and blow gently into the breather hose in the engine bay.
If you need to blow with any pressure at all then it needs removing and unblocking Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #759502 18th Feb 2019 10:36pm
landy andy
Take the filler bolt out the axe, then see if you can blow down the pipe, or use air line gently.
Post #759503 18th Feb 2019 10:37pm
lightning
You mean the small plastic pipes at the back of the engine? There’s no way l could get to those to blow down them!
Post #759510 18th Feb 2019 11:11pm
landy andy
Just lay on the top of your engine. Easy.
Or stick a rubber tube onto it to extend
Or use a compressor, gently. Even a computer keyboard blowy aerosol thingy. You will soon hear it if clear.
Post #759511 18th Feb 2019 11:35pm
4RF RDS
Or lift the hood (bonnet) onto the windscreen and lean in and blow into it. Its really is that simple. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #759524 19th Feb 2019 12:17am
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
does anyone have a picture of where to blow in to?
Post #759535 19th Feb 2019 8:49am
I tend to do it the other way, i.e., remove the tube from the axle and blow from the axle end to check the tube is clear, then make sure that the axle hole is clear by sticking a piece of bent wire down the hole (even though I can't see any way in which the axle hole can get blocked in the case of the type where the tube is colletted straight into the axle case).
Post #759539 19th Feb 2019 9:16am
landy andy
There are three plastic tubes at the rear of the engine above the bell housing. They have bent over tops like the top of a walking stick.
One is gearbox, on is transfer box, the other is front axle breathers. They aren’t labled though so need to be investigated which one. They are worth checking that they are clear whilst doing major service.
Post #759541 19th Feb 2019 9:25am
lightning
OK thanks for the advice/replies, l will have a go at it today.
Post #759542 19th Feb 2019 9:27am
lightning
Well, l took the breather out of the axle and blew through it using a piece of rubber tube.
It was clear so l
guess l need a diff nose oil seal as well.
Post #759624 19th Feb 2019 6:44pm
Hufflepuff
Rolling with laughter
I read that as "the Easiest way to remove the diff filler plug is to blow gently into the breather hose". I was wondering what your definition of gently is to blow hard enough to unwind the filler plug with breath alone! 2005 Td5 90 XS
1989 V8 110 CSW
Post #759630 19th Feb 2019 7:12pm
grafty99
I'll huff and I'll puff and I'll blow your filler plug out Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #759633 19th Feb 2019 7:14pm
4RF RDS
Just at the back of the motor by the air box
1967 MGB GT
Post #760000 21st Feb 2019 4:32pm
4RF RDS
Rolling with laughter Thumbs Up
1967 MGB GT
Post #760068 21st Feb 2019 10:22pm
