Home > Technical > TruckLite
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TruckLite
So just fitted the gen2 Trucklites, very impressed.
No wiring instructions with the lights so questions is, I know the two additional wires are for side lights and DRL but which is which?
Help!
Thanks
Duncan
Post #758984 16th Feb 2019 1:28pm
leeds
Duncan, unfortunately I will not be anywhere near our set up until next week.
The H4 connector gives negative, positive low beam and positive main beam.
The other two wires are purple and black, may have tracer colours.
These are positive from side light and an ignition fed positive for DRL.
Just put a positive feed alternatively to the two loose wires and you will soon tell which is the DRL feed as light is much brighter.
HTH
Brendan
Post #759002 16th Feb 2019 3:49pm
Tank
Thanks Brendan
Post #759179 17th Feb 2019 11:16am
Bluest
I didnt think the Gen 2 had DRL, just sidelights. Is there a drl version? Without checking cant be certain, but I thought that on mine the two extra wires were just pos and neg for the sidelight function. 2007 110 TDCi Station Wagon XS
Post #759182 17th Feb 2019 11:26am
leeds
There is a little bit of confusion now and I might have accidentally contributed as well.
Originally Truck-Lite made their standard headlight which were dip and main beam plus position/parking light. This version had a dark spot in the beam.
Truck-Lite then brought out a new improved version with an improved light pattern. Just to confuse the issue Truck-Lite kept the same product code! However they did change the packaging. So the only way to distinguish between the two versions was to look at the packaging. This was the case about 3-5 years ago when both versions were available on the market.
The above two versions were made in the US and product code 27291C
For that version the two wires would have been positive and negative for the parking light
Now Truck-Lite has brought out a new halo headlight which is made in South Korea by Signal Stat which is a division of Truck-Lite and has product code 27200C.
This version is a four function light dip and main beam, DRL and indicator.
The two wires are red and green now which one is ignition fed live and which one is indicator I can not remember
Now with this version please note you are only allowed one indicator per side at the front of a vehicle so if you use the built in indicator in the headlight then the original indicator must be disabled.
HTH
Brendan
Post #759259 17th Feb 2019 6:47pm
Tank
Hi Brendan
I am even more confused now. I purchased my lights from you about a month ago. So what ones do I have? I'd have to look for the box in the garage to get the code 😂😂😂 I have a black and purple wire I think?
Confused
Post #759279 17th Feb 2019 7:57pm
Bluest
The two version look quite different I think. You can view them on a Brendan’s website and should be able to tell which you have 2007 110 TDCi Station Wagon XS
Post #759280 17th Feb 2019 8:00pm
Tank
I ordered these ones
Truck-lite Generation 2 LED headlights – Right Hand Drive
*OE Appearance *Smoked reflector. *Integral Sidelight/Position light *EU approved. *IP69K (This is the newsest IP rating that was created specifically for vehicles that require regular high pressure cleaning e.g. 4x4s, quarry vehicles, dump-trucks etc) *Drop in replacement for any standard 7in Round H4 halogen headlamp including special edition model Defenders eg SVX, X-Tech, Fire & Ice, Raw. *Available in Right-Hand drive *Hard-coated polycarbonate lens *eCoat aluminum housing and internal structures *Metalized Reflector *9v-33v Multi-volt *12.8v, 1.80a (low beam), 3.60 amps (high beam) *25.6v, 1.00a (low beam), 1.80 amps (high beam) *1,300 Lumens
Price is for a pair
These are the second, improved generation of Truck-Lite 7 “LED Headlight. They offer considerably better illumination in front of the vehicle and an overall slightly higher light intensity.
Technical specifications:
Features: low beam, high beam, parking light / Position light
Two separate LED arrays
9-33V multi-voltage design, for use in 12V and 24V systems
Power consumption (12.8V): 1.8A (low beam), 3.6A (high beam)
Power consumption (25.6V): 1.0A (low beam), 1.8A (high beam)
Reference number (per headlamp): 17.5
Operating temperature range: -40 ° C to 50 ° C
Over-voltage protection up to 600V
Coated, robust polycarbonate lens
Aluminium body with coated reflector
Connection: Standard H4
Type: Direct replacement for # 6014, 6015, 6016, H6024 and PAR56 lamps
Moulded electronics for high tolerance to vibration, moisture or rust
Post #759284 17th Feb 2019 8:36pm
leeds
The two extra wires for the park/position lights are
Purple with white tracer is negative
Black wire is positive from side lights
HTH
Brendan
Post #759431 18th Feb 2019 4:58pm
Tank
Hi Brendan
So the model I have just has extra side lights and no DRL ?
Post #759565 19th Feb 2019 12:10pm
leeds
Correct.
Lights which are separate DRL's or DRL's incorporated in a combined light unit will have the light function code RL marked on them.
Brendan
Post #759576 19th Feb 2019 1:25pm
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
Rather than start a new thread I thought I should ask the question here...
I also have these trucklite headlights and I want to have the "park/position/side" lights come on with the ignition.
Is this possible and if so how complicated is it? Is it a case of simply connecting up the purple and black wires to an earth and ignition live point or will I need to fuse it, or use a drl controller?
And lastly does anyone know if theres a kit I could buy?
Post #778182 19th Jun 2019 8:22pm
macventu
I connected the Trucklite v2 purple wire to the black negative/earth (from the sidelights I believe) and the Trucklite v2 black wire to the red live. The DRL now works fine as per the photo below. No need for a DRL controller. The DRL light is fairly small, just a few small LED's, but does the job. (ps. ignore the long terminal block, I used it just to test!)
Post #783845 29th Jul 2019 5:46pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I believe mine were V1’s, I had to use a shorting link in replace of the dim dip relay (300tdi) to get full features, I now have DRL, dipped,main all with sidelights.
Post #783859 29th Jul 2019 6:22pm
deaallen
Does the DRL function work with the ignition on or only once you switch on the side & main lights?
Post #783911 29th Jul 2019 9:01pm
