shropshiredefender
Apparently - "Control module input power A" AAAh read your post properly - you already knew that
Not a clue what that means
No doubt someone more helpful will be along soon
11th Feb 2019 8:37pm |
sloderby1
From the JLR diagnostic description document:
There are actually 3 codes under this number - denoted by the subsequent failure type value:
U3006-16 Control Module Input Power "A" circuit voltage below threshold
U3006-17 Control Module Input Power "A" circuit voltage above threshold
U3006-1C Control Module Input Power "A" circuit voltage out of range
The symptoms for these in turn are noted as:
U3006-16 Possible EBD Warning Lamp ON ABS Warning Lamp ON TCS Warning Lamp ON
U3006-17 EBD Warning Lamp ON ABS Warning Lamp ON TCS Warning Lamp ON
U3006-1C ABS Warning Lamp ON TCS Warning Lamp ON
Clearly these are all related to the power input to the ABS module, which the documentation lists as pins 7, 16 & 35 of the ABS
Hope this helps
11th Feb 2019 9:06pm |
