![]() | Home > Td5 > Wing top, sills and rear quarter Chequered plating |
The Mammoth brand is OEM, I believe. Darren
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Mammouth stuff is nice quality, with good fittings and is neatly bent/formed over the front and side of the wing. I’m sure Brendan at 4x4 overland will also have some good quality German stuff too.
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Did a lot of research and I was told to go for Mammouth. Bought mine from LRParts in black but I'd ask Brendon if he sells good stuff too.
Mine is a 110CSW. Items numbers for the lower vehicle sills and rear quarter are: SLKIT01-CSW/B CNKIT02-110/B Wing tops depend on if you have the Ariel fitted and if you want the gasket. , but I believe on the Pumas, mammoth finish the plate before the airiel. Best to give them a call and check. I didn't do my wing tops as I didn't want to regret the decision and have holes in the bonnet. |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
As PCM said, chequer for Puma wingtops is narrower/shorter at the bulkhead end due to a Puma bonnet being slightly wider.
I've fitted Mammouth stuff before and very pleased with it ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
