![]() | Home > Maintenance & Modifications > Koni heavy track (NOT RAID) setup for 110 SW |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
It's a common issue...
Here's my solution: https://www.defender2.net/forum/topic49065...oilsprings Like you say, the Koni's help, but they are not the total solution, the springs are just too hard (in my opinion) when lightly-loaded... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
I find very hard to tune/match std tri-rate springs with shock abs. I spent a lot of time tunning both compression and rebound on my fox dampers and I got to the point where Im ok with the riding. Probably the best damper is the big koni raid. On those you can play with the rebound force.
NB. Fox now have a specific shock abs for the Defender. Puma 110" SW ............................................................. Earth first. Other planets later |
Cippo Member Since: 24 Oct 2012 Location: Florence Posts: 19 ![]() ![]() ![]() |
Anybody can give me an advice on how many turns i have to set up the rebound for those shocks?
![]() tx |
