![]() | Home > Technical > td5 twin alternator , but just using the upper mount |
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
Doesn't the TD5 alternator also have a vacuum pump for the brakes?
If you have to increase the length of vacuum pipe it could effect the brakes in a negative way, but I'm not sure. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
Yes it does have the vacuum pump, but there should be no problem extending the vacuum pipe provided suitable pipe is used. What would be harder is extending the oil feed and return lines for the vacuum pump.
Most twin alternator installations leave the original alternator and add a conventional (non-vac) second alternator. You could disconnect the original alternator's wiring and just use it as a pump, or you could fit an electric vacuum pump. |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
One question - looking for any info of placement second alternator in place of ACE (hydraulic controlled suspension used on Discovery 2) pump. I have A/C in our 130, so it is not possible to place the alternator instead of the A/C compressor. But there is some "empty place" used for ACE hydraulic pump. I don't want to reinvent the wheel, so any info is good. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Twin alt setup, but for those that don’t have ac.
https://gwynlewis4x4.co.uk/product/td5-def...tor-mount/ |
| razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403
thanks for your inputs chaps , will keep on searching
| All times are GMT |
