Home > In Car Electronics > Interior light options
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Been going round in circles on this one so looking for recommendations
I have added a tuff trek basket to my USW which is great however when loaded it obscures the rear interior light. As I am upgrading the 12v scockes I am looking at adding in some led lights in the rear. I was looking at adding these to the top of side trims so will easy to hide the wires etc and be high enough up to provide light.
Problem is I can’t decide on what lights. Looked at expensive lab craft ones and eBay but just can’t decide. Want it to be surface mounted so less butchering of the trim and look original as possible.
Any suggestions or other mounting options? Before I start ordering random lights off eBay.
Post #754601 28th Jan 2019 9:24pm
Have you had a look @ 4x4 overlander? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #754604 28th Jan 2019 9:28pm
Sphere
Yes but can’t see any interior lights on there.
Post #754610 28th Jan 2019 9:36pm
Maybe of interest?
https://www.4x4overlander.com/product/naka...ior-light/ ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #754619 28th Jan 2019 9:45pm
Sphere
Problem is the largo carrier is blocking the light in the middle.
https://tuff-trek.com/vehicle-accessories.html
I have thought about adding originals to the sides but not really the room in the trim.
Have been wondering about the stick on tape light?
Post #754625 28th Jan 2019 9:54pm
Sulisuli
Mud make a very nice interior light, I have two and very impressed with them
https://www.mudstuff.co.uk/mud-led-interior-lamp.html 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #754627 28th Jan 2019 10:01pm
donmacn
I was going to suggest a strip light above the back door, but I've just had a look at the cargo carrier, so that won't work either.
How about mounting a strip light onto the underneath of the carrier?? I'm sure you could put a thin aluminium strip inside the carrier to mount up into, with short bolts, which could then be trimmed or adjusted not to protrude into it, or compromise its loading at all.
The wiring could be fed back to the pivot point, and perhaps put into a bit of 'armouring' of some description - like a corrugated cable protector.
This way - if you provided new wiring to the new strip light, you could use that when the carrier was in the 'up' position; and the standard light for when the carrier was down?
It means you're not messing with the original light, and to be honest, a non-standard strip light, on a non-standard load carrier isn't going to look out of place? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #754631 28th Jan 2019 10:10pm
I fitted a simple strip light above the rear door with some home made brackets:
I also added a third interior light over the second row seats and coupled with decent LED bulbs, the light is fantastic.
More details HERE and HERE. Darren
Post #754634 28th Jan 2019 10:12pm
donmacn
custom90steve wrote:
Maybe of interest?
Seeing as these have both popped up in the same thread..... Sorry Sphere for the slight hijack Whistle .... I wonder if anyone has had the chance to compare the Mud and Naka options? Obviously there is a cost differential, but not so much that I'd get overly excited about when the time comes. I lean slightly to the 'standard' look of the Naka ones Donald
in the past..
Post #754635 28th Jan 2019 10:14pm
Sphere
Yes I looked at putting one above the rear door but as you say.
Currently I have a strip light cable tied to the underside that works well. Little bodged but rigged it up the day before we went away last year and it’s stuck.
Think it’s a good possibility.
Post #754638 28th Jan 2019 10:19pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Like that. Nice work mate.
Post #754640 28th Jan 2019 10:19pm
Maybe of interest?
I fitted some really decent LED bulbs to my existing lights and it totally transformed their performance. I'd almost go as far as to say it's my favourite mod to date, particularly over the winter. The bulbs weren't cheap at around £25 for three, but still better value than either of the options you've highlighted.
 Darren
Post #754642 28th Jan 2019 10:24pm
Sphere
Like the third light. Add that to the list
Post #754644 28th Jan 2019 10:25pm
donmacn
Thanks Darren - I do actually have a couple of those 'cheapy-ish' LED panels which fit in the existing light holders. They do work fine (when the headlining's actually in the car!) but as I am going to be re-furbishing the headlining, I thought I'd explore other options which might give a little more functionality.
For example, I thought I might find some units for the front which offered small 'reading lights' either side of the main light. There's a P38 Range Rover unit that might work. It wouldn't look standard, but the extra function might be worth it.
For the Naka and Mud ones, the option for a red light is tempting - particularly for the front of the car. If someone needs to light something up while I'm driving, I wouldn't lose any 'night vision'.
Just looking at options - not quite 'idly', but just to see what's out there, and what folks impressions are. Donald
in the past..
Post #754649 28th Jan 2019 10:37pm
Yeah, I started with a couple of the cheap LED panels but they retained a feint glow when switched off, which I got fed up of. Darren
Post #754651 28th Jan 2019 10:41pm
