![]() | Home > Maintenance & Modifications > Remap process? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
Dynachip and TD5inside will clme to you.
Yes maps can be done via post |
Yulong Member Since: 18 Nov 2017 Location: Aberdeen Posts: 110 ![]() ![]() |
Only one I've used is the BAS RRC which as you say isn't cheap at around £775 all-in.
BUT you do it yourself remotely and it's very easy do - send BAS some info about the car, they then send you a file which you upload to the module, plug it into the car's diagnostic port and it does the remap. Overall it's a 30 minute job. Once done, you can keep the module and use on further cars by paying a minor fee each time. OR you could sell the unit and recover say £450, hence "your" remap has cost you just £325 and it's been done at home. That's my experience, hope that helps explain the process of a "remote remap" somewhat. |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
BAS sent me a remap all the way to the Falklands so distance is not an issue
![]() All you need is a phone or iPad (I used my iPad mini), the app, and the ability to plug the car in and be connected to the internet and the car at the same time at least for the first occasion. You read off some data, send it to Pete, he sends back a map (on mine, late on a Saturday, great service) and then you flash it which takes a few minutes. After that, retaining the RRC lets you switch back and forth between standard and the BAS map, and do all the engine ECU checks for faults, display live values etc. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
Considering I already have a nanocom is there any benefit to keeping the RRC?
And you can't use the nanocom to add a map on the 2.2? |
