Home > Technical > Clutch Life
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
Clutch Life
Hi,
Just wondering what the lifetime of a clutch from new should be? Reading posts on here I keep seeing people with new clutches after 30K??
Assuming no heavy trailers.
Thanks
A
Post #753705 24th Jan 2019 6:54pm
My first gen clutch went at about 42 - 44k, I'm not on 70k on my 2nd gen.
The 2nd gen seems better in many ways but time will tell.
This is Genuine LR parts, but they were I believe updated. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #753708 24th Jan 2019 7:01pm
andrewlandy
Clutch Life
Thanks. I wonder if that is standard?
Did you use a LR dealer for the new one? Cost for labour and parts?
Do you know if there is a longer life clutch possible. 40K seems low for a clutch?
Post #753736 24th Jan 2019 8:47pm
Yes, dealer but I wouldn't use them again, never even put the earth strap securely back on it was loose. Rolling Eyes
Best part of £1000 I think, but that was over priced.. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #753745 24th Jan 2019 8:56pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Post #753746 24th Jan 2019 8:58pm
andrewlandy
Thx...
is this a hard job?
Post #753749 24th Jan 2019 9:02pm
leeds
If going for an aftermarket clutch would strongly suggest you look at Clutchfix here available from 4x4overlander here. We send them all over the world. Todays clutch went out to Australia.
They are specialist in clutches and make more then Land Rover clutches
Front clutch is a massive commercial clutch out of a 1950 lorry. Back one is for a 5.6 V8
This is a typical collection of clutches from Clutchfix
Brendan
Post #753775 24th Jan 2019 9:55pm
My experiences suggest that genuine Puma clutches are (or at least were, until production stopped) getting better but still aren't great. The lowest mileage replacement in my '07 was under 10k miles, the current clutch (which is I think number 5) has now done 80k miles but, although it doesn't rattle, has no resilience left in its springs and is really pretty horrible to drive. I hope it will last until the weather warms up when I will replace it. So my 2.4 Puma is on number 5 at 233k miles, by comparison my Td5 Discovery is on number 2 at 210k miles.
I reckon with the latest spec. of genuine clutch you should get 50k before it deteriorates, which is pretty dismal really. My next will be Clutchfix, not genuine LR.
Post #753787 24th Jan 2019 10:30pm
sako243
Depends a lot on how you drive I'd have thought. My 110 is on clutch number 3 at 187k but to be honest the last two were not needed.
I had the gearbox out at about 110k to replace and for the sake of £100 or whatever it was to replace the clutch I did so. The one that came out was hardly worn (previous owner but I'd put 50k on it).
Third clutch went last weekend at 186.5k as I had the engine out because the crank snapped and again seemed pointless not to and again clutch was hardly worn.
This is on a 300Tdi with a 1.2 transfer box so slip the clutch quite a bit pulling off and do a fair bit of towing and offroading but they appear to last well. Not genuine but Valeo, last couple have been 130 clutches. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #753800 25th Jan 2019 4:28am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
The clutches in older models were fine it's just the puma ones that are absolutely dire. Ok there's more torque and horsepower on pumas than earlier models but you would have thought they would have cured it by now.
Post #753801 25th Jan 2019 5:05am
You won't wear out a Puma clutch, it doesn't last long enough to wear out. The problem is that the springs in the driven plate take on a permanent set and at best lose their springiness and rattle around and at worst fall out altogether.
The most likely causal factor is the massive torque and fairly rough running (high angular vibrations) of the TDCi engine, which basically work hardens and then compresses the springs. There is a reason that a DMF is used on all applications (at least all I know of) except the Defender.
Incidentally it doesn't make a difference how much or how well you use the clutch, since the springs are being hammered all the time you drive. If you drive with a high degree of mechanical sympathy it will help, though.
Post #753870 25th Jan 2019 1:09pm
