Home > Technical > Rear wheel/axle drumming noise?
Dobby
Hi all,
So I’ve given myself a new noise to worry about. After changing the brake pads last weekend, I swapped the front and rear wheels over too, same sides though, front to rear only. And I gave rear prop uj’s a good squirt with the grease gun.
But now I’ve got a loud rhythmic drumming noise when I get over about 60mph. Definitely from the rear axle area. I can’t for the life of me work out what it is. The uj’s don’t appear worn and the tyres have equal tread on both sides.
I’d be very grateful if anyone can point me in the right direction. This is on a 2012 110 SW btw.
Cheers in advance,
Dobbs
Post #752695 20th Jan 2019 9:09pm
grafty99
First call would be to swap the wheels back and see if it stops.
Tyre wear can cause funny noises Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #752702 20th Jan 2019 9:51pm
LR90XS2011
I had what I thought was a rear diff rumble (tyres had 25k on them and had not been swapped about) , swapped the tyres about and the noise all but disappeared!! DEFENDER 90 TDCI XS,
Post #752719 21st Jan 2019 6:31am
Dobby
I thought I’d have to give that a go. Swapped tyres on other vehicles before and never had this, but definitely worth a try this weekend.
Post #752937 21st Jan 2019 9:45pm
grafty99
1990 Vogue SE
Post #753008 22nd Jan 2019 12:25am
Dobby
Yep, that fixed it. Annoyingly. I thought I might be able to wear the tyres out evenly, but the fronts must be too far gone in comparison to the rears. Ah well.
Thanks all.
Post #754818 29th Jan 2019 5:31pm
grafty99
The noise won't be detrimental to anything but your sanity. At least its an easy fix Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #754820 29th Jan 2019 5:55pm
