razz
chassis repairing 2mm to 3mm | |
morning all , i`ve found more damage to my old bus , i tend to plate the chassis in winter and then when its warmer , let it all in nicely , i use 2mm steel every where , do you recon , where it gets damaged the most , mainly along the bottom of the chassis , and up around the curved bit , where the tub mounts pipe sticks out , i should start letting in 3mm maybe , can anyone foresee a problem with that , tar
19th Jan 2019 9:33am |
