Home > Technical > OME BP-51
nico76
Norway 2007 Defender 110 Puma 2.4 SW Java Black
OME BP-51
Hi,
Anyone have fitted OME BP-51 on a LR Defender Puma?
Pleased to hear.
Nicolai
Post #751890 17th Jan 2019 3:43pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
I haven't yet but very interested too! 2 points ....wondering if ARB sells spare parts to rebuild them yourself and it seems they changed the numbers of the springs. Problem with the bypass is your ride height has to be spot on with the dampers otherwise the benefits are pretty much gone. m
Post #752016 17th Jan 2019 11:17pm
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Re: OME BP-51
nico76 wrote:
Hi,
Pleased to hear.
Nicolai
I have just fitted the BP51 as a project with ARB/OME. Happy to help with what I can.
Post #757386 8th Feb 2019 8:30pm
Bluest
Can you explain why the ride height is so critical? 2007 110 TDCi Station Wagon XS
Post #757395 8th Feb 2019 8:48pm
big110
not sure exactly what you mean. We fitted these and were required for longer OME springs as well. I think they are worried that if you do not have the long travel springs in theory at full shock extention, you could pop the spring out. We also required DC drive shaft.
Post #757397 8th Feb 2019 8:50pm
100inch
The bypass gives you a way to drive with 'different' valve settings across the entire shock length. Depending the amount of bypasses you have a more progressive one towards bump stop and a reduced rate towards full extension (nearly airborne/ deep wheeltravel). I had to use small spacers to fine tune the internal piston height to match it with the levels of bypasses. Try to find a drawing which shows the different levels of travel such a shock makes. They all work the same, external or internal. m
Post #757493 9th Feb 2019 10:17am
Bluest
Coool, thanks, makes sense. Thumbs Up 2007 110 TDCi Station Wagon XS
Post #757495 9th Feb 2019 10:27am
100inch
Post #757630 9th Feb 2019 9:45pm
