Home > My Defender > Fuji 110 LS3 build
Page 16 of 65 <123 ... 151617 ... 636465>
UtilityTruck
mcma1 wrote:
Drooping wings fixed this evening.
Was it an easy job? I’ve been putting off doing one of mine as I’ve heard conflicting things about how simple it is to do! 2014 Keswick Utility 2.2
Post #814319 9th Feb 2020 3:12pm
mcma1
Very easy. You just need to remember to also space out the brackets that hold the grille. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #814350 9th Feb 2020 6:12pm
mcma1
Very pleased with the badge.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #814353 9th Feb 2020 6:13pm
Stacey007
Badge is cool how will you infill it...
OOh and is it easy to do others.... with different text underneath Thumbs Up
Thumbs Up
Post #814377 9th Feb 2020 7:24pm
mcma1
I have another printing now with the recess not so deep. I will hit it with the polisher and then see how it comes up. It’s a silver sparkle filament. Then just in fill with a black touch up needle pen. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #814396 9th Feb 2020 8:20pm
mcma1
Finally
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #814550 10th Feb 2020 11:01pm
Sulisuli
Very nice Andy Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #814553 10th Feb 2020 11:07pm
andycam82
Northern Ireland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Great build mate Thumbs Up
Can I ask, where did you get the bracket/plate to convert the back seats to two individual seats & cubby?
All the best
Andy
Post #814560 11th Feb 2020 12:22am
JOW240725
Oooh I like the look of that Very Happy Good luck! James
Instagram @suffolk_rovers
Post #814589 11th Feb 2020 11:20am
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
mcma1 wrote:
So to continue the road to a factory finish exterior I needed to think about the zunsport grille. The Lazer ST4's are just too good to remove so last night took a few measurements and came up with a plan. Found a local mate that had a standard grille so collected this and then carefully started to Dremel the openings for the lights. This took me close to 3 hrs to get the grille to slide over them both nicely. Rather than drill out the filled surround I just added some black vinyl so the white didn't show and then was able to add some small black clips to secure it.
I also then made some extension brackets so that the Lazers could move out flush with the grille.
Really pleased with the results, ordered a new LR badge for it and just need to get it painted Santorini and then I can also think about adding the headlight surrounds after the wings get re fitted.
That looks fantastic. I've often scratched my head as to how you could fit lazers with an original grill. If you don't mind me asking, how did you make the extension brackets?
Post #814656 11th Feb 2020 7:59pm
mcma1
thanks
I just used some 3mm plate but then realised the lazer grille is slotted so I didn't need them. Just needed to loosen the bolts and push the lights as far forward as possible. Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #814657 11th Feb 2020 8:03pm
L110CDL
mcma1 wrote:
Finally
A thing of beauty Thumbs Up Clayton.
Keeper.
Post #814667 11th Feb 2020 9:01pm
mcma1
Dug out the spare stickers I had tucked away.
Also finished of the printed badge to see. But I think it needs to be machined from aluminium to work with the croytec parts. Have asked John if he could help.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #814684 11th Feb 2020 11:04pm
That will sound awesome. 👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #814685 11th Feb 2020 11:34pm
Pickles
Some VERY good stuff happening here.
Pickles.
Post #814686 12th Feb 2020 3:57am
