Home > Puma (Tdci) > Replacing A/C expansion valve without removing the dash? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I can't really advise on the valve, but would say that the if you end up having to take the dash out it's not that difficult. Can probably do it in an hour. There is a step by step in the factory workshop manual that can be downloaded from this forum. Just need to be methodical. 2007 110 TDCi Station Wagon XS
7th Jan 2019 3:15pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1025 |
Practically, yes you can once the ecu is out of the way, however it’s tight.
The downside is when you fit another one back is making sure you have no leaks, again it’s tight. Removing the dash is a 30 min job at max and you’ll know the new part is fitted correctly |
7th Jan 2019 5:56pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Honestly, I'd remove the dash. For 45mins easy work you'll save yourself 45mins or more of hassle and cursing. Also gives you the opportunity to inspect the other components whilst it's out and, if you're up for it, I'd split the heater box and clean it out. Surprisingly dirty they get! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
8th Jan 2019 1:00am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1285 |
If you do take the dash out, it would be worth checking the wiper wheelboxes for wear as these seem to be problematic.
With the dash out it is a quick job to change them. |
8th Jan 2019 8:49am |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
Hmm, I've had the dash out before and I thought it was a pig of a job. I might try from the engine bay first
8th Jan 2019 9:09am |
