Home > Technical > Defender Seatbelt Anchor Point
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I had to replace my seat belt on the 1987 LR90. The fixing point by the door/seatbox seems to be loose. The MOT expires today and I'm fairly certain this will be a fail.
Has anyone replaced this mount and if so, was it a big job? Not sure where it fixes to so if anyone has any photo's it would be appreciated.
Its the fixing ive attached a pic of, the 2 fixing bolts, the whole thing moves as if the part it fixes to has corroded
Post #749100 4th Jan 2019 8:34am
It just bolts down through the side sill/floor plate with a couple of M6 (or are they MCool bolts.
Hardest thing will be undoing them as more than likely rusted up underneath (as it's directly in the firing line of crud getting sprayed up... probably better just to tighten them up and shear them off.
Think there's one that goes through the back as well. M6
Post #749103 4th Jan 2019 9:10am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
It is one of those jobs that could take half an hour or a whole day depending on the corrosion. It could even involve replacement of the bit it attaches to.
Post #749105 4th Jan 2019 9:33am
kmac
I had to replace my seatbelt (due to it being frayed as passenger side kept catching in the door lock)
Mine was a 2009 Defender and did it last month - was very easy to take off the old one.
Post #749109 4th Jan 2019 10:08am
Buz
I think its going to be a major job!
All the fixing s have corroded around the seat box, here's a video
Post #749208 4th Jan 2019 5:42pm
But.... it's not the seatbox itself that the bracket bolts to... the brackets bolt through (and are secured by) the steel side sill underneath, and the B pillar (or back of the rear tub, whether it's a truck cab or SW)... the rear tub should have a steel plate behind it IIRC
Sooo.... with some large repair washers on the front of the seatbox, then you should be able to secure the seatbelt bracket AND stop that seatbox from wobbling around.
However.... as your seats are also bolted to that seatbox, I'd be slightly concerened about their security! Shocked
Post #749212 4th Jan 2019 5:56pm
Buz
Thanks DJ, I didn't think of that.
I'm thinking to go with large washers or even a steel bar with 2 holes drilled in it, just too get it through the MOT. Then, perhaps get a replacement seat box
Post #749214 4th Jan 2019 6:00pm
