![]() | Home > Tdi > Where's Wally?......or ...where's the spill rail banjo bolt? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
So.... ordered a new fuel spill rail for the 300tdi.
(I know now that I could have just got some fuel hose, and pushed it onto the existing fittings, but hey ho.) I hadn't realised that I needed a new banjo nut and washers to fit this, or that I needed a new nut and olive to connect to the fuel return pipe. But....by ![]() Or, I wonder if it's something of a generic banjo nut, like the ones on the fuel filter; or on the turbo oil feed hose, so that anyone used to Land Rovers would say "oh, it's one of those" - just that I haven't yet had any cause to disturb those. I've managed to get going again by simply replacing the 'last', longer pipe from the rocker cover down to the fuel pump. I used some 3.2mm internal diameter fuel pipe, but I hope this is just temporary until I can get all the other wee bits and pieces to fit the proper spill rail. Two out of the three pipes linking the injectors were squashed nearly flat, and the one from the rocker to the fuel pump was punctured, so after leaving the car for a few days it would take longer to crank. My thought was that maybe air was getting into the system, and letting fuel drain back down to the tank. Ta Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Here you go
![]() ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Not too clear
![]() Listed as kit bolt fluid passage, containing 4 banjo bolts and 8 joint washers 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Thanks Mash... I do appreciate the reply - but I'm sorry to say that's not what I'm after..
![]() I got that kit. It's the larger banjo nut - where the othe end of the spill rail fits onto the back of the fuel pump. At the bottom of your second pic, you can see the pipe, but no nut shown...! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
No worries fuel pump shows this bolt next to it:
Thanks again - that looks about right.
Which/where is that parts diagram? It's different, possibly newer than the one I've been looking at, which doesn't show that bolt. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Its a military parts list for the wolf, released for under the freedom of information act, google 2320-D-128-711 and you should be able to find the downloadable pdf
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Hi Mash, Thanks again. That worked fine. I'll need to load it down onto the PC. On an ipad just now, and it's always a bit glitchy with big pdfs.
Cheers. Donald Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks Retro - I wasn't familiar with that reference either - good to know.
My Luddite streak says it's not as intuitive as good old paper though! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
