Home > Puma (Tdci) > Puma 2.2 in limp mode after fitting new shocks
Danie Gouws
South Africa 2012 Defender 110 Puma 2.2 SW Alaska White
Hi, can anyone perhaps help with some advice?
I just had four new shocks fitted to my Defender 2.2 Puma.
Driving home from the tyre shop I noticed that the engine light was on and no power (limp mode).
How can that be?
Did they perhaps disturb some wiring in the engine bay?
Any advice on what to check or do?
Thanks
Danie
Cape Town
Post #748926 3rd Jan 2019 5:35pm
WindyJ
MAF sensor issue?
Post #748929 3rd Jan 2019 5:41pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I’d go with they’ve forgot to plug the MAF back in. Plug coming out the air pipe at the top side of the air box. Drivers side of the engine bay. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #748930 3rd Jan 2019 5:48pm
Danie Gouws
Thanks - I'll check the plug.
Will give feedback.
Post #748933 3rd Jan 2019 5:54pm
Danie Gouws
Nope - checked the plug. Seems OK and as it should be.
Darn - what a frustration and mystery!
Post #748943 3rd Jan 2019 6:23pm
MK
Likely the removed the air hose and maf wires. Check both clamps as well. Check both male and females plugs and pins/contacts. Gently pull each of the 4 wires on the female side.
Maybe they removed the air box cap and did not fit well. Puma 110" SW
Post #748946 3rd Jan 2019 6:43pm
Danie Gouws
Thanks MK.
The wires leading into the female plug looks "frayed".
Maybe they are simply due for a fix/replacement.
I'll try and get it to the mechanics as soon as possible.
The box and pipes and seals look fine.
Post #748950 3rd Jan 2019 7:12pm
Danie Gouws
Problem solved: it was indeed the wires that lead into the plug that had disconnected due to being frayed.
Luckily the place where I fitted the shocks is right next to a LR dealership.
The dealership's workshop quickly fixed the wiring - at the request of the tyre shop.
I'm immensely relieved and grateful.
Thanks for all the advice!
Post #749097 4th Jan 2019 9:31am
Co1
Post #749224 4th Jan 2019 7:36pm
