Home > V8 > sd1
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
sd1
is there much difference in the SD1 V8 and the range rover classic 3.5 V8 ?
Post #747899 29th Dec 2018 1:17pm
rustandoil
Bigger valves fitted to SD1, and the front cover is different putting the water pump at a different height.... Other than that not much
Post #747914 29th Dec 2018 2:52pm
CarMan
Higher compression as well I seem to recall and bit more power Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #747938 29th Dec 2018 5:41pm
tolley
thanks chaps , going to fit it into a range rover classic and wondered if there would be any problem fitting it .
Post #747943 29th Dec 2018 6:29pm
The blocks (on all the V8's) are more or less the same, so just unbolt the RR specific parts and fit them to the SD1 block.
IIRC the LR manifolds are quite restrictive, cast jobbies; although I dont 't know what the SD1 ones are like... you may get a bit more ooomph out of fitting better ones to the rangie. might entaul some welding on the downpipes though.
Post #748079 30th Dec 2018 5:37pm
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
I would agree that an exhaust manifold change can make a big difference to this engine. I had a genuine 90 V8 Station Wagon some years ago and, after fitting a SS exhaust with balanced tubular manifolds it was like having a different engine - it would pull a next higher gear in most situations with ease. A great improvement. Don`t drive faster than your angel can fly!
Post #750561 11th Jan 2019 5:13pm
