Home > Td5 > Crank position sensor
excossack
To remove the Crank position sensor is it a simple case of unplug the cable, undo a screw, and remove. Insert new one and replace removed bits? 1999 Defender TD5 110
Regards
John 2E0DHN
Do you know what a nemesis is?
Post #747806 28th Dec 2018 7:55pm
htb2
It is that easy
Post #747807 28th Dec 2018 7:57pm
excossack
Cheers. With all the oil leaks around that area i was going to make sure the CPS is clean of oil. 1999 Defender TD5 110
Regards
John 2E0DHN
Post #747810 28th Dec 2018 8:06pm
landy andy
Some have spacer, some don’t. So just be aware whilst stripping if yours does, doesn’t, and if it comes out with sensor.
Post #747837 28th Dec 2018 9:34pm
excossack
Cheers LA 1999 Defender TD5 110
Regards
John 2E0DHN
Post #747839 28th Dec 2018 9:38pm
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
