Home > Technical > Runs fine with full fuel tank
dexter
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
Puma starts and runs perfectly when the fuel tank is full. Once about a third used takes a little longer to start and there's a hesitation on acceleration particularly when cold. Fill the tank and all is perfect. It has been consistently like this for several months.
No fault codes, new crankcase breather, new injectors, new pressure valve at the back of the pump, new fuel filter.
Any thoughts?
Post #746885 22nd Dec 2018 1:58pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
I would start with the easy checks first. Have you checked fuel tank breather pipe for blockage, or is there signs of a vacuum building up in the tank as you use fuel (hissing when you remove the fuel cap).
Post #746886 22nd Dec 2018 2:21pm
ericvv
When you take the fuel cap off after your fuel tank has been running from full down to say 80% or so, do you hear a hissing sound? If so, it could mean that your fuel cap breather valve is blocked, and a vacuum is developing in your fuel tank which makes it more difficult for the fuel pump to draw a fuel supply. Same symptoms as you describe happened to me years ago, and a new fuel cap with a proper working breather valve solved it all,
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #746887 22nd Dec 2018 2:22pm
Sulisuli
Dexter I have a genuine lockable fuel cap with the rubber leash and 2 x keys taken off my 2105 XS avalaible for sale if it’s the fuel cap that’s at fault, good luck with solving the problem Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #746890 22nd Dec 2018 2:42pm
dexter
I thought about the cap and put a new one on a few weeks ago. Also there is no vacuum build up. A new fuel tank breather was installed sometime ago as the old one was leaking but as there is no vacuum in the tank I assume that the breather is working okay?
Post #746892 22nd Dec 2018 2:44pm
jst
Are those symptons from multi drives taking fuel level down or from one journey? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746926 22nd Dec 2018 7:13pm
dexter
Multiple journeys.
Post #747063 23rd Dec 2018 4:29pm
jst
so over time you would therefore expect the tank to stabilise.
does sound fuel supply related. not something stupid like sender is giving message for restricted performance thinking tank is too low?
sounds like the first option changes/check have already been done. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #747082 23rd Dec 2018 6:58pm
