Home > Off Topic > Sankey trailer towing.
leeds
Have been asked how a Freelander can tow a Sankey trailer fitted with a Nato hitch when the Freelander has the standard 2 holes tow ball. The Nakatanenga 2 to 4 holes adapter will not work with a Nato hitch.
This is for a one off trip to get the Sankey trailer back to base where a Series is available.
Will a Dixon Bates universal coupling work? Is the one with a 25mm pin suitable for a Nato hitch? Or is it only the Nato pintle suitable for a Sankey trailer fitted with the original towing coupling?
Brendan
Post #746807 21st Dec 2018 9:59pm
No, the DB coupling isn't big enough for a NATO ring.
There isn't really a solution without lashing something together and even if you made up some sort of adapter, it'd be awfully low. Darren
Post #746816 21st Dec 2018 10:17pm
leeds
Thanks Darren. Was uncertain so thought I would check first.
Brendan
Post #746819 21st Dec 2018 10:28pm
It wouldn't be legal to tow any trailer with with a NATO lunette behind a Freelander since there is no type-approved method of attaching a suitable pintle to the Freelander (or a Disco Range Rover, etc). Only the Defender can do it.
The only way to do it would be to modify the trailer to use a ball hitch or ring and pin hitch.
The NATO lunette should only be towed with a military pintle, there are very few pin/jaw couplings that are suitable and then only for an old-style rotating lunette. The later military trailers with a fixed (non-rotating) lunette must only be towed with a rotating pintle.
The practical solution is to get someone with a Defender to do it, or use a car transporter trailer.
Post #746842 21st Dec 2018 11:23pm
leeds
Thanks BW. Have not owned or towed a Sankey trailer so when I was asked if the Nakatenga 2 to 4 hole adapter would take a NATO hitch it was outside my knowledge zone. The Nakatanenga 2 to 4 hole adapter will not take the NATO hitch as it is a different hole pattern.
So it does not seem legal or practical to tow a Sankey with a Freelander. Will give the information over and let them make a more informed decision.
Thanks for your help.
Brendan
Post #746854 22nd Dec 2018 12:16am
