Home > Puma (Tdci) > Designing a digitally controlled heater system, help needed. |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 321 |
Whether you work with a permanently open return flow and determine the heating power by throttling the forward flow, or whether you also have a permanent bypass, only makes a difference in the speed at which the heating responds. The original solution is probably only due to the simplicity of the solution or the value for money of the component.
Your idea is good! |
19th Dec 2018 2:46pm |
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 148 |
I’ve found a four pipe valve that should be suitable and have written some code to control it. Should be able to test a proof of concept using a heat setting of 1 to 10 before I get any further down the road of proper automated climate control.
23rd Dec 2018 8:41pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
I'm really interested in this project. Like yourself I find the heater controls nothing but stupid.
Is this also going to interface with the A/C? |
24th Dec 2018 9:53am |
It absolutely could control the AC, although cars I’ve driven that have auto climate as standard have all had AC control on a seperate button.
Once the valve is installed with manual cnntrol working I’ll be moving on to automatic temperature control, which might require more complex code than a simple thermostat due to the sudden variance in coolant temperature with engine work, plus the large / slow reacting thermal mass of the inside of the vehicle. When that’s working satisfactorily I’ll be looking at fan control and hepe to be able to program a ‘half’ setting as, in my opinion, position one on the standard system is too fast / loud. |
24th Dec 2018 10:37am |
I suppose the A/C always work on a separate button, as you say.
Even having better manual control would be a massive improvement. Better fan control would me amazing as well. Although I'm a programmer by day I wouldn't be working with this type of stuff so this is a very cool project to me. I'm a mobile developer so I'm scratching my head trying to think how I could be of use! 😂 |
24th Dec 2018 11:02am |
B4Lamb Member Since: 21 Mar 2015 Location: Abergavenny, Wales Posts: 233 |
does the valve you have found operate with a servo motor or stepper motor, or just a simple solenoid? what microcontroller are you planning to use and are you going to use full PID control? "You are never to old to learn something new" |
26th Dec 2018 9:07pm |
Soleniod.
Using an Arduino, will decide weather to go with PID depending upon how successfully it works without it, to begin with. |
26th Dec 2018 9:12pm |
Yes good idea but maybe some differential on top of proportional will be required to prevent overshoot. Have you managed to characterize the valve (current drive vs aperture opening or flow rate) ? I'm interested in your project success and wish you well. "You are never to old to learn something new"
26th Dec 2018 11:29pm |
The valve is either open or closed, control is implemented via PWM at 0.3 ish Hz. So far I’ve written some code to control the PWM with ten presets from 0 to 9, I plan to test witha bit of real world driving / use before getting into automatic control and PID.
26th Dec 2018 11:47pm |
ok, I get it. I'm assuming he valve is designed to be controlled like that and not wear out by constantly shuttling every 3 seconds. How does the factory fitted valve work that's connected to the temperature rotary knob? Is that a proportional valve and did you consider just driving that with a servo or stepper motor and gearbox to get the required torque? "You are never to old to learn something new"
27th Dec 2018 12:03am |
Yhat’s how it’s meant to be controlled.
I considered hijacking the existing cable operated valve but many have had reliability issues with them and mine is quite vague anyway. I’m aiming for an OEM standard finish and didn’t feel stepper motors / gearboxes/ linkages, potentially under the bonnet with associated heat cycles etc would give me that. This valve is one moving part and is a proven device and method of control. |
27th Dec 2018 8:06am |
Okay good point. The temperature control in my TDCI seems to be quite linear but it's hard to get a cab temperature that is right. It certainly shuts completely off and opens completely on which is no different from your digital solenoid valve but there is a usable gradient between the two extremes that potentially could be used in a linear feedback control loop. Anyway good luck with your approach, it sounds like it will be effective with minimal moving parts. "You are never to old to learn something new"
27th Dec 2018 9:38am |
edo Member Since: 20 Aug 2018 Location: Surrey Posts: 358 |
Likewise the heater is staggeringly . Even off it chucks out heat, and having the AC button on but fan in off, still runs the system??
27th Dec 2018 1:24pm |
Just did a test of the standard heater system in my 2007 Defender 90 Hardback. Conditions: Start: Engine cold at ambient Ext Temp - approx. +10 C Heater turned to full on HOT External Air Intake Fan setting 1 Setting: Windscreen + Legs Ch1, External Air Temp (Blue) Ch2 Heater O/P Legs - drivers side (Red) Ch3 Cab Rear - near rear door (Green) Ch4 Cab Front - passenger seat shoulder height (Brown) Ch4 Heater O/P Screen - Passenger side (Violet) Notes- Windscreen Heater O/P thermocouple fell out as annotation but was returned. At about that time the engine had reached normal temperature At 2nd Annotation heater control turned from full Hot to full Cold As you can see the heater belts out very hot air (+80 C) but when turned to off it drops to a low level (not consistent with edo comment above). My defender does not have A/C fitted. I may repeat test with other settings such as intermediate settings of the temp control knob. "You are never to old to learn something new" |
28th Dec 2018 5:04pm |
