Home > Puma (Tdci) > Help - Major oil heamorage on 2.2
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Can anyone provide some advice on a major oil leak that has suddenly developed on my 2.2 . I noticed a small leak a month ago but could not determine the source - although I suspected it might be a circular plastic cover in the timing cover. This has now developed into a major blow out. Before I start digging around - I am looking for advice from the wealth of expertise and knowledge on this forum. Photos below.... thanks for any help! I might add that the daux drive belt is dry and all the oil spray is on the left hand side of the vehicle.
Post #745879 15th Dec 2018 7:36pm
MK
Early Pumas had a oil leak problem on the vaccum pump. Puma 110" SW
Post #745882 15th Dec 2018 7:57pm
Siwynne
Looks similar to what mine did. It was the timing chain cover. The pulleys then threw oil everywhere.
Two covers and shaft seals where they pass through the cover under warranty and its bone dry.
This was after land rovers first attempt
Post #745892 15th Dec 2018 8:53pm
