Home > Technical > Fog Light not illuminating, but turning RH taillight off
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
I've been pulling my hair out all morning with this one.
One of the dogs pulled a variety of wires from out my rear lights while jumping about in the back - my fault as I didn't put the metal cover back on.
I've gone to reconnect them all back up again, but I seem to be having an issue when I switch the rear fog light on, the RH/OS taillight goes out (and the fog light doesn't illuminate - however the foglight illuminates on the dashboard). I thought the towing electrics might have caused the problem, but I've disconnected all of these and the problem is still there!
My rear RH/OS indicator also isn't working (this might be the holder, which I'm just about to check).
Any ideas? Bad earth?
ETA: would have helped if I told you which vehicle it is on! 1989 90 HT.
Post #745843 15th Dec 2018 2:56pm
Mo Murphy
I'd pull the earth's off first and give them a clean, it costs nothing.
If it's a later version with the earth's going into a header then it's conceivable that the earth wire going into said header could have been disturbed by Mr. Dog.
HTH
50 Shades of Pennine Grey
Post #745844 15th Dec 2018 3:36pm
Woody3
Thanks Mo.
Twas indeed a faulty earth. Made a new earth point and it's all back up and running.
Cheers! Thumbs Up
Post #745864 15th Dec 2018 5:35pm
