![]() | Home > Maintenance & Modifications > Spring Thing |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
You could use spring isolators in the back of a 90. However they are around 10mm thick. Or 1 inch spring spacers. Puma 110" SW
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5990 ![]() ![]() |
If you are happy with everything, apart from the look, just fit spring spacers. Gwyn Lewis sells a large range so you can do what you wish.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3759 ![]() ![]() ![]() |
I may have a pair of 1” spring spacers going free over the Christmas period. Yours if you want them?
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Co1 that is very generous, thank you. Will PM you
Thank you all for your input. Going to try the spacers first of all. Much cheaper than new springs - especially with Co1’s kind offer.
