Home > Td5 > TD5 heater not working
Greeny
With winter well and truly here, I thought it was about time that I fixed my heater. It suddenly stopped working in the respect that when I pull the toggle to engage the heater on the left hand side of the dash, it doesnt work at all. Nothing is coming out of the heater vents below the windscreen.
Any ideas of how to fix this or what the problem is?
Thanks in advance! Instagram - @Land_Rover_Defender
Post #744477 7th Dec 2018 1:19pm
dorsetsmith
fuse 13 (20 amp) ok in the passenger fuse box Question
Have you voltage at fuse 13 Question
Toggle to engage the heater on the left hand side of the dash, this in side your dash
(red arrow ) black ground wire make shore connected
If the fuse has blow check fan blade and motor will mover and not seized Exclamation
Post #744480 7th Dec 2018 1:41pm
4RF RDS
What Dorsetsmith said about covers it all. It is truly a very simple system and super easy to trace problems. Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #744523 7th Dec 2018 6:44pm
Greeny
Brilliant, thank you!
I will let you know how I get on, cheers Very Happy Instagram - @Land_Rover_Defender
Post #744604 8th Dec 2018 12:35am
