![]() | Home > In Car Electronics > USB port |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Most of the round ones e.g. Blue Sea or even Chinese ones will fit in the cigar lighter socket (after removing the cigar lighter)
Don't know of any that is an exact fit for a switch. The Carling one (which is mega expensive) . is the closest switch like one but will be too big for any switch other than the electric window ones, which I presume you will need to keep. |
This one is the other rectangular one around
https://www.dx.com/p/car-modification-3-1a...Ae_iRP7SL4 |
| Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 202
Cheers guys
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
If you're feeling a bit handy in the DIY department you could fit a panel mount USB port to a switch blank. There are all sorts of shapes and sizes out there if you have a google
[/list] |
Cheers Hank I'll look into that looks good
