- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
rallysteve
Yes but you will have to fit the wider radius arms from a 300TDi or later Defender or Discovery.
If the axle is from an 02'> TD5 it will have the larger panhard rod bolts too so will need the later panhard rod and mount off a later vehicle.
Reuse your original front propshaft
Steve 02' 110 TD5 Double Cab Rebuild Thread
2nd Dec 2018 7:18pm |
