Home > Td5 > Spade connectors for rear windscreen motor
alexatnd
The rear windscreen electrical connections seems to have a 3 pin AMP connector at the top of the motor and 2 spade connectors ( +ve and -ve) near the bottom. Problem is they're not the standard size Santa - 1977 Series 3 - new chassis, tub, brakes
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road
Effie - 2004 110 TD5 County
Post #743583 2nd Dec 2018 4:47pm
PaulMc
They're 2.8mm terminals.
The factory harness uses a latching 2-way connector -
I've not been able to find that particular connector - but, have found a similar unlatched connector, which works -
. Paul.
Post #743593 2nd Dec 2018 5:58pm
alexatnd
Cool,
Got any info of where you got the connector from?
Rgds
A Santa - 1977 Series 3 - new chassis, tub, brakes
Post #743607 2nd Dec 2018 7:09pm
alexatnd
ok ebay has loads of 2.8mm spade terminals how about the connector terminal block ? Santa - 1977 Series 3 - new chassis, tub, brakes
Post #743609 2nd Dec 2018 7:21pm
PaulMc
alexatnd wrote:
Cool,
Rgds
A
I'm selling them Thumbs Up
PM me here or on LandyZone
Regards,
Paul Paul.
Post #743617 2nd Dec 2018 8:10pm
