![]() | Home > In Car Electronics > Fusing a Solar Panel |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
Both. The fuses are there primary to protect the cables - in case of a short, not to burn. So they should be as close to the power source (panel, regulator), as possible. Secondary protection is to protect the equipment itself (panel, regulator, battery) in case of over current.
First fuse as close to panel as practically possible. Second fuse between regulator and battery, if they are close and wires are short, place the fuse close to the battery. But if the are in the "opposite ends" of car, use two fuses - first next to battery, second next to regulator. In case of a short somewhere in the middle, both battery and regulator are energy sources and this energy can burn something on the way. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Both is typically better, but have a look at the maximum short circuit current of your panels. 6-7A is about typical for a 100W panel, and assuming you're using decent cables they'll cope with the maximum potential current from your panels without doing anything dangerous.
It's very, very important to have a fuse at the battery end because if there's a cable fault then a (relatively) thin cable coming from a solar panel is not going to cope with the hundreds of amps that your battery can provide and that can lead to a fire. If it was me, I'd just put one in at the battery to make things simpler. |
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732
Thanks both
I presume a simple in-line blade fuse is ok? 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
