Home > For Sale & Wanted > [For Sale] 160W folding Renytek folding solar panel
familymad
This high quality waterproof 160W folding solar kit with German Mono-crystalline cells is designed to provide free power for charging 12V batteries, for example in boats, campervan, caravan and motorhome and any other system with a 12V battery or battery bank
It comes with everything needed for battery charging: advanced 20A 12V solar charge controller, 5m cable with a battery plug, fuse and crocodile clips. You can start using the kit in seconds - just unfold, connect to battery, aim toward sun and start charging.
kit includes:
High efficient 2 x 80W Monocrystalline solar panels
Waterproof 20A solar controller for Gel, flooded or sealed batteries
Integrated Aluminium stand
5 Metre cable with connector and fuse
Battery crocodile clips
Rigid protective case
Pulse Width Modulation technology is used to increase charge acceptance and prolong the life of a battery. The technology can also recover some lost battery capacity. The solar charge controller is rated to IP66 therefore completely sealed, making it safe to use in all weather conditions.
Solar Panel Details
2 x 80W Monocrystalline Solar Panels
Maximum power: 160 watts
Maximum voltage: 17.80V
Maximum current: 8.98A
Open circuit voltage: 20.80V
Short circuit current: 9.70A
Dimensions Folded: 1005 x 505 x 70mm
Dimensions Unfolded: 1005 x 1010 x 35mm
Purchased for £260 in August. Runs a 100l fridge easily and charged our batteries at the same time. Sold camping 130 and having a clear out of bits.
£200 ono 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #743347 1st Dec 2018 9:29am
familymad
Bump 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #745595 13th Dec 2018 8:50pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Any pictures?
Post #765212 24th Mar 2019 8:21pm
familymad
Will get it from the loft later and take some 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #766041 30th Mar 2019 10:09am
familymad
Will get it from the loft later and take some shots 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #766043 30th Mar 2019 10:12am
