Home > For Sale & Wanted > [For Sale] Ring RPP265 33AH Jump Starter 12V / USB / 240V in
lohr500
Thought I would offer this on here if anyone is interested before it goes on eBay.
Top of the range Ring RPP265 boost start pack with a 33Ah battery.
Just fitted it with a brand new battery that I purchased from Ring.
It claims to be capable of starting a 3500cc vehicle and spun over my 2.2 Defender easily several times in the past when the battery was flat.
As well as a boost starter it has a built in 240V socket (300 W max), USB and 12V cigar socket outputs snd a built in LED array work lamp.
Reverse polarity check when using the jump leads. LED indicators show internal charge and state of battery on vehicle being jump started.
Can be charged through the 12v cigar socket, vehicle to vehicle, or by using the mains charger.
The unit sits on a tidy charging base, so no need to connect the charger directly to the unit. Although the mains charger will plug directly into the unit if you want to leave the charging base at home.
More details here :
https://www.ringautomotive.com/en/product/RPP265
£125 or nearest offer, plus £16 postage due to the weight. Reduced to £120 including postage. Or welcome to collect from Skipton area, North Yorks.
Post #743339 1st Dec 2018 8:52am
lohr500
Price dropped to £120 including the postage.
Post #743985 4th Dec 2018 3:58pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
I've got one of these and it's fantastic. I've even run an angle grinder off the 230V socket when I had to do some cutting away from mains power source and it took it like a champ - so I ended up using it for almost exclusively running power tools remotely for a while. GLWTS
Post #743988 4th Dec 2018 4:08pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Yes please pm sent
Post #744015 4th Dec 2018 5:59pm
lohr500
Sold to Tegner. Thanks.
Post #744062 4th Dec 2018 8:48pm
Tegner
Arrived today many thanks
Post #744346 6th Dec 2018 4:32pm
