Home > Puma (Tdci) > Defender puma no engine management light not starting
Garyboythompson
2007 Defender 110 Puma 2.4 CSW Bonatti Grey
Hello group new member
Looking for some help I've got a defender 2.4 tdci 110on a 2007
I've just changed the battery
And it won't start
I will list what it's doing
No engine management light on
Or heater plug light
The temperature gauge is up at the top I've checked the fuses under the dash I've also checked under the seat to and still are getting nothing ive also checked the battery terminals and seem all ok
I've tried to put a snap on code reader on it but it won't link for some reason
Is there any thing else I can try
Post #743096 30th Nov 2018 4:09am
LR90XS2011
i remember a thread on here that says something like you have a few seconds to switch the ignition on after reconnecting the battery, try disconnecting for a couple of minutes, reconnecting and immediately press unlock on the key fob and switch on. unless of course you have already done this, or my memory is failing me. DEFENDER 90 TDCI XS,
Post #743101 30th Nov 2018 7:21am
dorsetsmith
hi have read link below may shred light on your problem
https://www.defender2.net/forum/topic64833.html
Post #743103 30th Nov 2018 7:57am
WindyJ
So there is an inline ecu fuse actually outside of the fuse boxes...useful to know, could easily be missed!
Post #743106 30th Nov 2018 8:49am
